Date/Time: Fri, 03 May 2024 04:55:59 +0000
how to add value per candle?
View Count: 542
[2020-11-28 18:55:06] |
HeyUgly - Posts: 233 |
while watching number bars chart is there any way to graph the value of each candle {ValHi/Lo}? say if im running a 5 or 15 min chart to plot this per candle during the orderflow? |
[2020-11-28 19:28:32] |
Ackin - Posts: 1865 |
numbersbars HL.png / V - Attached On 2020-11-28 19:28:17 UTC - Size: 173.1 KB - 213 views |
[2020-11-29 13:54:06] |
thanks for the response, i was looking for the actual 70% value hi/Lo of each candle not the actual hi/lo but this was a very cool trick! do you know if there is a way to shade the candle or have it draw the value hi/lo of the candle ? Date Time Of Last Edit: 2020-11-29 13:55:22
[2020-12-01 03:27:01] |
You can do this with the Volume by Price study. Refer to: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines And refer to this particular configuration: Volume By Price Study: One Volume Profile per Chart Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
