Date/Time: Thu, 02 May 2024 05:09:49 +0000
[Programming Help] - [Feature Request (?) / Programming Help (?) ] Text Tool: vertical text orientation
View Count: 551
[2020-11-28 03:42:50] |
User112177 - Posts: 8 |
Hello SierraChart, Is it possible to update / modify the Text Tool [or, may be, add another tool - to avoid conflicts with existing code?] which could allow VERTICAL text orientation? Main reason is that there is much more free space above / below the the graph, and , for example, when I put additional text [using ACSIL] above or below the graph - it often overlaps. IMHO, could be very useful. If NO / too complicated - please let me know as well [I'll have to think about something else then :(( ] PS Found that code is actually there - it HAS to be used with the "Vertical Line" [picture attached]; problem is that how to place this Vertical Text / Vertical line [??] into resired position [time + level] ?? Thanks a lot in advance. Sincerely, KZ Date Time Of Last Edit: 2020-11-30 05:13:23
Text=HorizinalOnly.png / V - Attached On 2020-11-28 03:37:47 UTC - Size: 24.04 KB - 203 views XL=VerticalTextIrientationExample.png / V - Attached On 2020-11-28 03:37:55 UTC - Size: 7.36 KB - 189 views |
