Date/Time: Thu, 02 May 2024 14:15:25 +0000
new computer
View Count: 504
[2020-11-27 15:06:49] |
Mayor Quimby - Posts: 11 |
Hi, I have been seirra on my macbook through parallels and have just switched to pc. I have gone through the transitional steps that have been provided on the website however the screen looks stretched out and the text size linked to the tools on the graph are oversized and I cant reduce the size of them. I've gone through global graphics settings and put the text size on everything to 8 and its still oversized. Please could you advise. Thanks |
[2020-11-30 16:31:30] |
John - SC Support - Posts: 31293 |
If you are changing the Global Graphics Settings and they are not affecting your chart, then that chart must be set to use the Chart Graphics Settings. Select Chart >> Graphics Settings - Chart and either select the option for Use Global Graphics Settings instead of These Settings, or make the changes to the graphics for that chart in that window. Refer to the information here: Graphics Settings: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
