Date/Time: Mon, 06 May 2024 15:48:25 +0000
CLZ20
View Count: 496
[2020-11-27 01:00:37] |
User633898 - Posts: 28 |
Hi, I have problem to get the chart working for Nymex CLZ20 and also CLX20. Market data download both stopped at 14:28 Nov 20, 2020. My data subscription should have included Nymex. Can you please advise what is the problem? Thanks |
[2020-11-27 04:24:25] |
The US markets closed early on 2020-11-26 due to a US holiday. There are also shorter trading hours on 11-27 as well.
[2020-11-27 18:46:55] |
ticinotrader - Posts: 378 |
User633898: CLX20-NYMEX expired on 16 October 2020 CLZ20-NYMEX expired on 18 November 2020 You should follow the current front month now, it is the CLF21-NYMEX. It is also important to use the proper symbol format, so instead of CLF21, you have to enter CLF21-NYMEX. Hope this helps. |
[2020-11-27 20:07:47] |
Thank you for post #3. We did not pay close enough attention to the fact that they specified a date significantly in the past and it did not relate to the US Thanksgiving holiday.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-27 20:08:09
