Date/Time: Sat, 04 May 2024 09:26:49 +0000
Switching from mac (parallels) to windows 10
View Count: 984
[2020-11-26 22:38:30] |
Mayor Quimby - Posts: 11 |
Hi, I have been seirra on my macbook through parallels and have just switched to pc. I have gone through the transitional steps that have been provided on the website however the screen looks stretched out and the text size linked to the tools on the graph are oversized and I cant reduce the size of them. I've gone through global graphics settings and put the text size on everything to 8 and its still oversized. Please could you advise. Thanks |
2020-11-26 22.38.03.jpg / V - Attached On 2020-11-26 22:38:14 UTC - Size: 179.89 KB - 216 views Attachment Deleted. |
[2020-11-27 04:22:56] |
There are two Graphics Settings windows where Fonts can be set. Make sure you are using the correct one. More information is at the beginning of this page: Graphics Settings: Introduction Also refer to: Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-27 14:10:52] |
I've set the text to the smallest possible on all options and it doesn't effect on chart text. I've gone from a 13.3" (2560 × 1600)macbook pro screen to a 32" Full HD 1920 x 1080p monitor. |
[2020-11-27 20:06:25] |
Tell us the specific menu commands you are selecting to get to the graphics settings window. Are you using Chart >> Graphics Settings or what?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-27 20:06:36
[2020-11-27 20:18:58] |
Both Chart >> Graphics Settings and Global Settings >> Graphics Settings
[2020-11-28 07:57:46] |
Ok, there really should not be a problem. Open a new chart through File >> Find Symbol. Change the Chart Text Font through Global Settings >> Graphics Settings >> Fonts. Does the Chart Text font change on the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
