Date/Time: Thu, 02 May 2024 17:43:31 +0000
Number after the dot
View Count: 423
[2020-11-26 06:37:23] |
User441331 - Posts: 1 |
I'm sending you a screenshot of two graphs of the DAX In one I have numbers after the dot and in one I do not I do not find this definition in the system how to operate it and how to disable it and it is very important to me for the purpose of my trading and strategy for example 13302.5 13303 13303.5 or 13302 13303 ? |
david kremer.png / V - Attached On 2020-11-26 06:33:59 UTC - Size: 112.04 KB - 156 views Attachment Deleted. |
[2020-11-26 08:54:34] |
Refer to this Chart Setting: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
