Date/Time: Wed, 08 May 2024 02:40:13 +0000
Rithmic update
View Count: 468
[2020-11-26 04:15:58] |
ManuelGraf - Posts: 16 |
Hello I just wanted to start prop trading, but I found out that some of the prop firmes used to Support Sierra chart but they told me since there is an issue with some rithmic Updates, they no longer Support Sierra chart. Is this something I can expect to get fixed in the next time or not? Thanks |
[2020-11-26 08:47:35] |
Yes, Rithmic is working on new integration to Sierra Chart. That should be available soon. When it is, it does solve the technical integration issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
