Date/Time: Sat, 04 May 2024 17:58:42 +0000
use on two laptops
View Count: 471
[2020-11-25 16:58:16] |
User475663 - Posts: 12 |
I have Sierra charts 3 with amp futures and using cqg. I would like to use sierra on two laptops, Is it possible without any additional cost. |
[2020-11-25 18:15:09] |
John - SC Support - Posts: 31362 |
Yes, you can use Sierra Chart on two systems simultaneously without any additional cost, that is allowed as part of our standard agreement. Refer to the information here: Sierra Chart Purchase and License Information: Licensing / Number of Systems But, if you are wanting to use these simultaneously, then you will most likely have to pay an additional fee to CQG for the data feed. You will need to ask them about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
