Date/Time: Mon, 29 Apr 2024 00:24:51 +0000
Chart 'To' date is today and cant be changed
View Count: 554
[2020-11-25 15:35:40] |
User425804 - Posts: 1 |
Hi - in chart settings the date range ends today and cant be changed. Im sure I have signed up for the delayed data feed so not sure if this is related problem. Im signed up to the Advanced level 5 subscription. Can you help please as its stopping my chart update. Regards Gavin Date Time Of Last Edit: 2020-11-25 19:11:19
[2020-11-25 17:35:16] |
That date range for the file is supposed to have an end date of Today. That is appropriate. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DateRangeInFile If you are having a problem, then it is not related to that. What exactly is the issue you are having? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-29 21:43:31] |
If you have any chart updating issues, refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
