Date/Time: Mon, 29 Apr 2024 20:56:42 +0000
Changing Chart Periods Using a Keyboard
View Count: 429
[2020-11-25 12:18:15] |
RolandC - Posts: 54 |
Hi When I am on a Intra-day chart and I try to change to a daily period, I type 1d on the keyboard, but it changes to 1 minute. I have to type 1w, which takes me to 1 week, which means I am now obviously on a historical chart, then 1 and that takes me to the 1 day. How can I change to a Daily period from an intraday chart with the keyboard? |
[2020-11-25 14:10:18] |
You need to double check this, because definitely this could not be the case. We tested this. Although check this setting: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) It must not be set to Intraday Chart Only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
