Date/Time: Mon, 29 Apr 2024 19:46:59 +0000
Trade buy bid -3/trade bsell +ask
View Count: 632
[2020-11-25 09:22:45] |
User657945 - Posts: 226 |
I dicovered these 2 buttons TBB3T and TSA3T and I would like to use this functionality in the window for attached orders to avoid selecting "market" and get a bad price execution while using this function could get better entry price. I search in the option availbale in the trading window for attached orders but I did not find it(may be with another name?) could you please in case add this function and if yes with the possibility to choose the numbers of thicks? thx |
[2020-11-25 14:48:14] |
You can add Control Bar buttons for these: Control Bar This is all. They cannot be added to the Trade Window. However, you can set up a dedicated control bar for them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-25 15:00:49] |
thx I already did it:( The question was the possibility to import that function into the trading window
