Date/Time: Fri, 03 May 2024 13:48:58 +0000
How do I move bracket orders when they happen to be at the same spot?
View Count: 631
[2020-11-25 03:15:06] |
User845052 - Posts: 75 |
Sc, I ran into an issue where I had bracket order stops on top of one another. I had to move one of them, but I could not select it without much difficulty which could be devastating in a live trade. Is there some way to select a specific bracket to move, or some way to stagger them horizontally so that they do not overlap entirely? Thanks |
[2020-11-25 14:42:08] |
No this is not supported. But you can certainly link multiple Stop Attached Orders by using the OCO Group: All OCO Groups: Attached Orders: OCO Group (Group) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-25 20:18:25] |
I'm adjusting things to subvert the issue. One thing that will help is the Transparent Trade Drawings setting under Chart Settings. The problem is that the text is black and hard to read, a little too hard. I have not found any option to change the text color, which would be necessary when considering the transparency option. Am I missing something?
[2020-11-25 20:47:24] |
To facilitate the response, Chart Trading Order Line Text Color does nothing
[2021-04-23 04:49:37] |
jonnyot - Posts: 6 |
Is there a way to move one side of my bracket order towards/away from the current price while in replay mode. Also if I am entering a number of trades during replay- is there somewhere to review my trade entries/exits to assess the success of my trades?
[2021-04-30 08:25:13] |
Is there a way to move one side of my bracket order towards/away from the current price while in replay mode. Yes. Refer to:Chart Trading and the Chart DOM: Modifying and Canceling Orders on the Chart Also if I am entering a number of trades during replay- is there somewhere to review my trade entries/exits to assess the success of my trades? Refer to:Trade Activity Log: Trades Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-30 08:25:38
