Date/Time: Fri, 03 May 2024 20:12:12 +0000
Problems with real data
View Count: 399
[2020-11-24 20:36:32] |
g4500 - Posts: 25 |
Hi Just start to used real data trough Denali Server today. But now some historical info in one of my chartbook disappeared and i don t understand why. I checked few options but not working.(attached files) Can you help me? |
Captura de pantalla 2020-11-24 a las 20.28.12.png / V - Attached On 2020-11-24 20:35:59 UTC - Size: 596.8 KB - 169 views Captura de pantalla 2020-11-24 a las 20.32.41.png / V - Attached On 2020-11-24 20:36:08 UTC - Size: 913.94 KB - 163 views Captura de pantalla 2020-11-24 a las 20.32.49.png / V - Attached On 2020-11-24 20:36:15 UTC - Size: 966.74 KB - 187 views |
[2020-11-24 22:17:24] |
John - SC Support - Posts: 31360 |
The first thing is to remove the TPO study and make sure that the underlying data is correct.
[2020-11-25 14:38:11] |
Also refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. If that does not resolve the issue then re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
