Date/Time: Fri, 03 May 2024 05:52:24 +0000
Rithmic data feed problem?
View Count: 1110
[2014-02-15 01:11:40] |
User98399 - Posts: 3 |
I am with AMP futures with Rithmic data feed...attached is a 233 number of trades per bar chart and its showing overlapping bars.. How can I fix it so that the tick chart is properly display on chart? http://www.sierrachart.com/image.php?l=139242632840.png |
[2014-02-15 01:16:08] |
This is explained in help topic 47 here: http://www.sierrachart.com/index.php?l=doc/helpdetails47.html#RepeatingBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-15 01:16:40
[2014-02-15 01:23:54] |
thank you. One more question, do I need sierra chart package 5 in order to get the most accurate tick charts or is package 3 good enough.
[2014-02-15 01:27:00] |
Any package is fine including package 1.
