Date/Time: Thu, 02 May 2024 12:41:28 +0000
Stop Question
View Count: 1718
[2013-04-18 15:04:20] |
Richard Reyes - Posts: 98 |
I am running an automated Excel Study spreadsheet and the study BUYS and SELLS using columns K, L, M and N. In other words one goes long and then one goes short and so on and so on. My question is, can I put a Stop into the study orspreadsheet that will close a position should a BUY or SELL signal be ignored? Will I put the Stop into the spreadsheet or use the "Attached Orders" window? Please advise. Many Thanks.
[2013-04-18 19:47:15] |
Yes you can do this. You need to use a Stop Attached Order and this is documented here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#UsingManualOrAttachedOrdersExits Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
