Date/Time: Mon, 29 Apr 2024 01:15:36 +0000
DAILY OHCL
View Count: 537
[2020-11-24 06:56:53] |
User612401 - Posts: 5 |
Hello Can you tell me why on the Eurex DAX I have a difference of DAILY OHCL between the 16 minutes chart and the 15 minutes chart, on the 16 minutes I have the OHCL level of the day and the 15 minutes of the day before .. I work in 10 seconds and the problem is the same. I join you 2 screnn shot for the results. Cordially. Bruno Dastan |
16 mn OK.png / V - Attached On 2020-11-24 06:55:38 UTC - Size: 258.38 KB - 196 views |
[2020-11-25 15:04:38] |
First, we want you to update to pre-release 2201: Software Download: Fast Update Let us know if you still see the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 15:05:18
[2020-11-26 09:35:47] |
Hello The problem is solved with version 2201. Have a good day. Cordially. |
[2020-11-27 17:22:15] |
Hello Another bug encountered on my graph I have 4 studies TPO Day -1 Day Month Year The Day-1 and the day in Time Period Type (in3) are in Day, the month in month, and year in year, if I pass my chart in day, the setting of Day-1 and day passes in month!!!!! , you have to go back to the settings to change them, I’m in version 2201. cordially. Bruno Dastan. |
[2020-11-28 23:33:27] |
We are not understanding post #4.
