Date/Time: Mon, 06 May 2024 04:40:02 +0000
Connection issues
View Count: 365
[2020-11-24 03:40:51] |
Monserrate G - Posts: 27 |
I know that you are no longer support Rithmic Trader Pro and that if I continue with one up trader with their funded accounts I would need to download Bridge files and use older versions of platform. My question is the following: After 12/2020 will I still be able to trade with Sierra Charts and One up Trader? Thanks |
[2020-11-24 09:26:29] |
Yes this is going to be the case. You will still be able to use Rithmic.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-24 09:26:42
