Date/Time: Mon, 06 May 2024 18:16:30 +0000
Doese SC list the formulas for the indicators it uses ?
View Count: 1077
[2014-02-14 20:46:25] |
Auspicatum - Posts: 46 |
Hello, I am trying find the source code for the "Super Trend Stop" indicator . Thanks for your time ! (also, unrelated, but is there a way to make the Trendlines drawn on the chart, show the price change over that distance ? ) Date Time Of Last Edit: 2014-02-14 20:47:13
[2014-02-14 21:01:27] |
For the source code, have a look in the ACS_Source subfolder in the folder that Sierra Chart is installed in. Use the Tools >> Chart Calculator tool for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
