Date/Time: Sat, 04 May 2024 03:26:24 +0000
Trying to run two instance of Sierrachart - Do I need two subscriptions/ licences?
View Count: 961
[2014-02-14 19:35:46] |
User29698 - Posts: 28 |
I am trying to run a source/ destination setup where I want one copy to act as data source and the other to be connected to an other broker, but using data from source SC instance. Do I need to pay two subscriptions to do so? I was running such a setup without problems during a trial and now use SC package 3 through AMP and use IB as the broker in the other instance. But this no longer works after the trial?
[2014-02-14 20:12:04] |
Sierra Chart - Max - Posts: 5605 |
If you are using an AMP provided Sierra Chart account, then you will not be able to connect to IB. To connect to IB you will need to have a direct Sierra Chart account: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support Date Time Of Last Edit: 2014-02-14 20:12:59
