Date/Time: Mon, 29 Apr 2024 00:52:16 +0000
Format of Price EURUSD Denali Data feed Trade DOM
View Count: 668
[2020-11-23 09:20:53] |
MuUs! - Posts: 45 |
Hello Sierra, I have noticed that by default, prices in the Trade DOM for EURUSD spot do have 5 pipettes difference. I have seen that the settings to be changed to have a 1 unit granularity are in Chart Settings: "Tick Size", "Currency value per tick". In the Documentation it is said that I should pay attention to setting these parameters properly because they will affect Live trading. I wanted to change the visualization in the DOM so that I could see all price levels to the 1/10th of a pip granularity, so I have changed the tick size to 0.00001: what should be the appropriate "Currency value of a tick" to ensure consistency? Thank you |
[2020-11-23 21:16:16] |
In this case you would take the existing Currency Value per Tick and divide it by 5.
[2020-11-23 21:35:38] |
MuUs! - Posts: 45 |
I am sorry, I still have not clear what are the settings I should use. Does it mean that I should use 0.00001/5 for "Currency value per tick"? Thanks
[2020-11-24 09:44:00] |
What is the existing currency value per tick setting?
[2020-11-24 09:48:12] |
MuUs! - Posts: 45 |
0.00005. So that means that the new one should be 0.00005/5 = 0.00001?
[2020-11-25 13:40:24] |
MuUs! - Posts: 45 |
Hello Sierra, could you please confirm what I have written in the last message? Thank you.
[2020-11-25 14:03:34] |
We cannot answer the question because we do not know what the existing Currency Value Per Tick setting is in your particular case. Refer to post #4. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 14:03:46
[2020-11-25 14:12:45] |
MuUs! - Posts: 45 |
The default one was 0.00005. The instrument is EURUSD
[2020-11-25 15:22:30] |
Ok we understand now. So the answer to post #5 is yes.
