Date/Time: Sun, 28 Apr 2024 13:50:04 +0000
to sierra chart developers
View Count: 1187
[2014-02-14 19:32:15] |
User17402 - Posts: 5 |
volume value area lines indicator would it be possible to add a feature to this indicator, to the "time period type". can you add an option to pick the number of bars to use, instead of just minutes. I would like to use this indicator on volume charts, but not use it based on minutes, but rather used it based on bars - like 1 bar or 2 bars, etc. thanks if you are able to do this. |
[2014-02-15 21:37:47] |
We will check on this. There might possibly be an easy way we can do this. If not, then we do not foresee getting to this anytime soon.
[2014-04-15 02:10:22] |
We should be able to do this, and we have not gotten to it yet. We will try to get this done by the end of next week.
[2014-04-20 00:18:39] |
lotus123 - Posts: 23 |
ok. thank you.
[2015-09-06 07:38:35] |
The Volume by Price study has been enhanced to do all that the Volume Value Area Lines now does, so what you want is now supported.
