Date/Time: Mon, 29 Apr 2024 22:36:54 +0000
2196 studies not working correctly
View Count: 498
[2020-11-23 08:00:27] |
User97684 - Posts: 136 |
Hi , Please help - since the update yesterday 22.11.20 these studies are not working right. I removed and re-added - same stuff . PLease advise actions, thank you |
Sierra acting weird.png / V - Attached On 2020-11-23 07:59:40 UTC - Size: 186.43 KB - 228 views |
[2020-11-23 08:26:06] |
I can see that both OHLC single point and OHLC studies are referencing the previous day, and not the current.... changing the study parameter to 'ref days back' to 1 and then back to 0 makes no difference to the display - still showing the previous day It is on this chart only, bythe looks of it..... |
[2020-11-24 16:38:57] |
Nick_ON_CAD - Posts: 20 |
I have the same problem.. It works properly up to 2191
[2020-11-24 16:58:11] |
Provide the chart that has the issue by following these instructions and we will look into what the problem is: Support Board Posting Information: Providing Chartbook with Only a Single Chart Remove all studies from the chart except the one particular study there is a question about. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-24 16:59:15
[2020-11-24 17:48:15] |
Hi , I posted the chart earlier, in my subsequent to this support request named 'Daily OHLC', so it's being looked into. Dont know how to reference it , sorry |
[2020-11-24 19:57:22] |
Ok we are checking on this now.
