Date/Time: Sun, 28 Apr 2024 08:42:07 +0000
Hide a study - NBs calc Values
View Count: 517
[2020-11-22 18:53:47] |
nicktrader - Posts: 665 |
In some cases I set the status for Studies to "Hide", because I do not want to see the values in the chart, but in the ChartValueWindow. Unfortunately this is not possible for the study "NBs Calc Value". If you set the status to "Hide" no value will be shown in the ChartValueWindow. |
[2020-11-24 07:59:41] |
Did you miss my question?
[2020-11-25 15:02:31] |
What you say is true and the only solution in this particular case is to use the study: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 15:02:56
[2020-11-26 05:50:57] |
In this case my solution is more a "Quick&Dirty" solution I placed the "NBs Calc Value" Study in Region2 and "closed/ hid" the "Region2 Window" on the chart but did not hide the study. |
[2020-11-26 20:33:22] |
We will see about adding an option to allow a study to show in the chart values window but also still be hidden.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-26 20:34:00
