Date/Time: Wed, 01 May 2024 08:01:06 +0000
AddMessageToLog not writing to log
View Count: 571
[2020-11-22 06:56:48] |
User153286 - Posts: 44 |
I have the following code in my custom study, but it's not appearing in the Message Log int MyInt = 50; float MyFloat = 2.5f; SCString Buffer; Buffer.Format("My integer is %d. My float is: %f", MyInt, MyFloat); sc.AddMessageToLog(Buffer,0); Any suggestions why it won't write to the log? |
[2020-11-22 14:51:11] |
Make sure that Window >>Disable Visible Message Logging is unchecked. Otherwise, that function call in your code must not actually be getting called. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-22 14:51:30
