Date/Time: Mon, 29 Apr 2024 09:52:51 +0000
Settlement price
View Count: 1441
[2020-11-21 00:57:05] |
RIFT - Posts: 124 |
Hello SC Team, is there a way to show the settlement price on the intraday chart instead of overlaying from the historical chart? Peace |
[2020-11-21 21:52:45] |
We need to create a study that supports this. We will do that.
[2020-11-22 15:52:01] |
Actually we do have this study already. Refer to: Previous Close Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-23 10:37:00] |
RIFT - Posts: 124 |
is there a similar way to display "Period OHLC-Variable Period" (week, month, pw-week, pw-month) for example on a driagram where only 4 days are loaded instead of overlaying?
[2020-11-23 18:45:44] |
That study does have a Number of Days to Calculate Input setting which you can use.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-23 18:46:03
[2020-11-24 14:21:02] |
RIFT - Posts: 124 |
Can you please also include the Number of Days To Calculate function in the Previous Close Line Study? Cheers |
