Date/Time: Mon, 06 May 2024 03:23:49 +0000
TPO second volume bar for current period only
View Count: 550
[2020-11-20 18:26:39] |
jollenj240 - Posts: 3 |
Is there a way to have a second volume bar to show for the current period only? Please see image attached. I copied and edited a chart of what I'm trying to accomplish.
SC2ndvol.png / V - Attached On 2020-11-20 18:26:16 UTC - Size: 76.65 KB - 217 views |
[2020-11-20 21:09:44] |
John - SC Support - Posts: 31379 |
There is no way to specifically do what you are asking for, but you can add a separate Volume by Price profile to that chart that is separate from the TPOs and has it's own period. Refer to the information here: Volume By Price Study: Set as Independent Volume Profile for TPO Chart And an example of how to set this up is here: Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-21 13:48:19] |
Have a look at this TPO Profile Chart Input: Time Price Opportunity (TPO) Profile Charts: Number of TPO Profile Periods You can set it to: One Period Of Fixed Time Length At End: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-24 18:02:41] |
Thank you. I followed those steps was able to get it to align to the right of the chart. Did I do it right in the attached screenshot? It gets blocked by the chart drawings and values that are also on the right. Is this the only way that this is possible?
scsepvol.png / V - Attached On 2020-11-24 17:58:09 UTC - Size: 60.05 KB - 188 views Attachment Deleted. |
