Date/Time: Wed, 01 May 2024 17:11:42 +0000
Incorrect values for Daily OHLC study for > 2191
View Count: 472
[2020-11-19 14:11:13] |
Nick_ON_CAD - Posts: 20 |
Just wanted to report a problem for > 2191 The Daily OHLC study shows values offset by one day. Example: Setting the study to show yesterdays OHLC shows two days back. Input:Reference days back = 1 ---> displays values as if the setting input was 2 Everything is offset by one day. Version 2191 works correctly, tested up to 2198 and still offset by one day, I can post screenshots if required. Thank you so much, Regards, Nick |
[2020-11-24 21:11:38] |
I have seen other people having this problem on the forum too. It appears that it is only wrong when using the evening session, in case that helps.
for submission.Cht - Attached On 2020-11-24 19:19:09 UTC - Size: 17.43 KB - 196 views |
[2020-11-25 14:36:01] |
This is now resolved. Update to prerelease 2201: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
