Date/Time: Tue, 07 May 2024 03:27:50 +0000
No column for close
View Count: 1070
[2014-02-13 15:53:42] |
Tonkadad - Posts: 235 |
How do I reference the close of a bar in the spreadsheet system/alert. I want an arrow every time the close of a bar is above moving average. |
[2014-02-13 17:24:56] |
Sawtooth - Posts: 3993 |
Try this: =AND(E4<AA4,E3>AA3) where AA is the moving avg This will alert on the first crossing. |
[2014-02-13 17:45:28] |
Thanks Tom, the last is the same as the close?
[2014-02-13 18:47:16] |
Use the E column.
[2014-02-13 20:38:14] |
Yes
