Date/Time: Wed, 01 May 2024 05:00:25 +0000
GC chart
View Count: 1129
[2014-02-13 15:44:08] |
User022189 - Posts: 35 |
my chart for Gc today is dated 2-12 at 13:45:44---what's the best way to update it?
[2014-02-13 16:11:55] |
Sierra Chart - Max - Posts: 5597 |
Change the Symbol of the chart to a current one following the steps here: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support |
[2014-02-13 16:54:51] |
the problem is not the incorrect symbol, it's updating the symbol
[2014-02-13 17:13:25] |
If this is an Intraday chart, then refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html If you still need help, post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-13 17:13:40
