Date/Time: Mon, 23 Nov 2026 01:57:43 +0000
Candlestick overlay on footprint behind the footprint pic attached
View Count: 2140
| [2020-11-09 20:06:41] |
| HeyUgly - Posts: 290 |
hello 2 same overlay setups, one on left is proper, candle stick is to the front, one on the right i cant figure out what setting is making it do this, i want it overlyed as the top like the one on the left. which setting needs to be tweaked? |
| [2020-11-09 21:33:35] |
| John - SC Support - Posts: 48610 |
You need to move the order of the studies on the Chart Studies window so that the Study/Price Overlay is above the Numbers Bars study. Refer to the information here: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-25 13:44:05] |
| Manerva Funding Financial - Posts: 16 |
Can you move the order without having to delete the study you created
| [2021-08-26 20:19:05] |
| Tonkadad - Posts: 235 |
There are buttons to move studies up/down on the Chart Studies window. Highlight the study you want to move and click the respective button. Move Up Move Down |
