Date/Time: Fri, 03 May 2024 12:14:35 +0000
Standard Replay - transacted volume 1sec bursts/updates
View Count: 404
[2020-11-08 20:35:29] |
User311344 - Posts: 136 |
Hey, Is this normal Standard Replay behaviour that I see ca. 0.5-1 sec updates of transacted volume (both on volume indicators and T&S window) while depth info (DOM, Depthbars, etc) is updated contiously and very fast as in real time. Transacted volume shows up as 0.5-1 sec regular bursts/updates, certainly not in continous manner as in real time. Is there any way to start seeing transacted volume exactly the same way as in real time? Thanks (Of course I have 1 tick data enabled) Date Time Of Last Edit: 2020-11-08 20:59:53
[2020-11-08 21:36:20] |
What symbol is being replayed and what particular date do you notice this with? Just one date is enough.
[2020-12-02 07:40:50] |
I was using data collected before 2150 and using build 2150+ to replay it. When data is collected by current build everythings fine. Thank you |
