Date/Time: Sat, 04 May 2024 12:14:57 +0000
Two time frames, two time bars in the same chart
View Count: 1094
[2014-02-13 11:10:59] |
Carl71 - Posts: 125 |
The Overnight prices fill most of the chart space, so I ask you if it's possible to set two time frames, for example starting from the overnight open to the regular session with a 90 minutes chart and then with a 5 minutes chart till the close, in one chart only Thanks Date Time Of Last Edit: 2014-02-13 11:56:10
[2014-02-13 18:31:36] |
No.
