Date/Time: Thu, 02 May 2024 19:32:23 +0000
How to decrease the width of a candle stick without decreasing the space between the candles?
View Count: 1684
[2014-02-13 08:33:24] |
Futurestrader77 - Posts: 126 |
Dear support team, I am using a volume profile of each candle stick. I would like to drecrease the width of the candles without descreasing the space between them. I attached a picture from Sierra Chart. The volume profile is not good visible. I attached a picture from Market Delta. I would like to have my chart to look the same way (candles with volume profile). Thank you! Best regards, |
Candle with Volume Profile - Sierra Chart.PNG / V - Attached On 2014-02-13 08:33:05 UTC - Size: 73.67 KB - 646 views Candle with Volume Profile - Market Delta.PNG / V - Attached On 2014-02-13 08:33:14 UTC - Size: 61.5 KB - 488 views |
[2014-02-13 09:40:30] |
Global Settings >> Graphics Settings >> Other >> Candlestick Width %
