Date/Time: Fri, 03 May 2024 09:47:26 +0000
Moving Individual Symbols from Chart book across different monitors
View Count: 1025
[2014-02-12 22:19:05] |
User22591 - Posts: 133 |
You responded the above title a few days ago but did not achieve what I am looking for if it can be done. If you did I did not see the information.
[2014-02-12 22:53:10] |
We assume you are familiar with how to detach a chart from the main Sierra Chart window and move it to another monitor? It seems like this is what you want to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
