Date/Time: Mon, 09 Nov 2026 09:38:18 +0000
Rithmic data feed
View Count: 826
| [2020-11-02 19:15:55] |
| the white rabbit - Posts: 24 |
I have just changed my CQG data feed to rithmic and I ca not longin as I get : "Connection error message from service:Rithmic trading/ Logon error received from server" Can you please help Thank you Reading Internal Order ID file. | 2020-11-02 14:02:35.525 Reading Trade Orders file. | 2020-11-02 14:02:35.729 Reading Trade Positions file. | 2020-11-02 14:02:35.733 Reading Account Balance file. | 2020-11-02 14:02:35.735 UDPListener (1352). Port 22904 | Listening on UDP port 22904. | 2020-11-02 14:02:35.775 Software version: 2138 64-bit | 2020-11-02 14:02:35.775 Primary Thread ID: 17060 | 2020-11-02 14:02:35.775 Usage end date: 2021-02-02 | 2020-11-02 14:02:35.776 Enabled for: Advanced Features 2. | 2020-11-02 14:02:35.776 Enabled for: Sierra Chart Historical Data Service. | 2020-11-02 14:02:35.776 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-11-02 14:02:35.776 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-11-02 14:02:35.776 Current selected Data/Trading service: Rithmic Trading | 2020-11-02 14:02:35.776 Custom symbol settings values: enabled | 2020-11-02 14:02:35.776 Chart Update Interval: 500 | 2020-11-02 14:02:35.776 Intraday Data Storage Time Unit: 0 | 2020-11-02 14:02:35.776 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-11-02 14:02:35.776 2020-11-02 23:02:35 Local computer time | 2020-11-02 14:02:35.776 2020-11-02 19:02:35 Local computer time in UTC | 2020-11-02 14:02:35.776 2020-11-02 14:02:35 Local computer time in SC Time Zone | 2020-11-02 14:02:35.776 2020-11-02 19:02:33 Server time in UTC | 2020-11-02 14:02:35.776 Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-11-02 14:02:35.776 Program path: C:\SierraChart\ | 2020-11-02 14:02:35.776 Data Files path: C:\SierraChart\Data\ | 2020-11-02 14:02:35.776 OS Version Number: 10.0 | 2020-11-02 14:02:35.776 Locale Setting: C | 2020-11-02 14:02:35.776 Allowed protected custom studies: Smaug_SC_Library | 2020-11-02 14:02:35.776 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-11-02 14:02:35.799 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:02:35.853 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-11-02 14:02:35.994 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-11-02 14:02:35.994 Received 5 login tokens. | 2020-11-02 14:02:36.305 Symbol settings MD5 received. Request ID: 1. | 2020-11-02 14:02:36.385 Symbol settings are up-to-date for rithmic.trading. | 2020-11-02 14:02:36.385 Files to Open on Start up | File does not exist: C:\SierraChart\Data\Volume Colour Bars.StdyCollct | 2020-11-02 14:02:39.379 Files to Open on Start up | File does not exist: C:\SierraChart\Data\Volume Colour Bars.scss | 2020-11-02 14:02:39.379 Rithmic Trading | Port for executable: 64129 | 2020-11-02 14:02:41.397 Listening socket (924). Port 64129 | Closed. | 2020-11-02 14:02:41.398 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:02:41.401 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:02:41.441 Rithmic Trading | Bridge process is running. | 2020-11-02 14:02:43.443 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64129 | 2020-11-02 14:02:43.443 DTC Client socket (1) | Creating socket. | 2020-11-02 14:02:43.443 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:02:43.444 Rithmic Trading | Connected to server. | 2020-11-02 14:02:43.446 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:02:43.446 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:02:43.446 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:02:43.450 Rithmic Trading | Sending logon request message. | 2020-11-02 14:02:43.450 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:02:43.452 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:02:43.456 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:02:43.457 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:02:45.465 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:02:46.360 Rithmic Trading | Received logon response. | 2020-11-02 14:02:46.360 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:02:46.360 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:02:46.360 Rithmic Trading | Logon error received from server | 2020-11-02 14:02:46.360 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:02:46.360 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:46.360 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:02:46.456 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:02:46.456 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:02:46.456 Rithmic Trading | Disconnected. | 2020-11-02 14:02:46.457 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:46.457 Rithmic Trading | Port for executable: 64143 | 2020-11-02 14:02:48.463 Listening socket (992). Port 64143 | Closed. | 2020-11-02 14:02:48.463 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:02:48.465 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:02:48.514 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:02:50.505 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64143 | 2020-11-02 14:02:50.505 DTC Client socket (2) | Creating socket. | 2020-11-02 14:02:50.506 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:02:50.506 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:02:52.538 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:02:52.538 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:02:52.538 DTC Client socket (2) | Closed. | 2020-11-02 14:02:52.539 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:52.539 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:02:52.549 Rithmic Trading | Disconnected. | 2020-11-02 14:02:52.550 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:52.550 Rithmic Trading | Port for executable: 64147 | 2020-11-02 14:02:54.573 Listening socket (940). Port 64147 | Closed. | 2020-11-02 14:02:54.574 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:02:54.575 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:02:54.604 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:02:56.599 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64147 | 2020-11-02 14:02:56.599 DTC Client socket (2) | Creating socket. | 2020-11-02 14:02:56.600 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:02:56.600 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:02:58.641 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:02:58.641 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:02:58.641 DTC Client socket (2) | Closed. | 2020-11-02 14:02:58.641 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:58.641 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:02:58.668 Rithmic Trading | Disconnected. | 2020-11-02 14:02:58.668 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:02:58.668 Rithmic Trading | Port for executable: 64150 | 2020-11-02 14:03:00.659 Listening socket (1396). Port 64150 | Closed. | 2020-11-02 14:03:00.659 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:00.660 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:00.711 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:02.713 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64150 | 2020-11-02 14:03:02.713 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:02.713 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:02.714 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:04.749 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:04.749 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:04.749 DTC Client socket (2) | Closed. | 2020-11-02 14:03:04.749 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:04.749 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:04.772 Rithmic Trading | Disconnected. | 2020-11-02 14:03:04.772 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:04.772 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-02 14:03:06.550 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:03:06.550 DTC Client socket (1) | Closed. | 2020-11-02 14:03:06.550 Rithmic Trading | Port for executable: 64153 | 2020-11-02 14:03:06.769 Listening socket (1328). Port 64153 | Closed. | 2020-11-02 14:03:06.769 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:06.769 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:06.797 Rithmic Trading | Bridge process is running. | 2020-11-02 14:03:08.804 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64153 | 2020-11-02 14:03:08.804 DTC Client socket (1) | Creating socket. | 2020-11-02 14:03:08.804 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:08.805 Rithmic Trading | Connected to server. | 2020-11-02 14:03:08.807 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:03:08.807 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:03:08.808 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:03:08.813 Rithmic Trading | Sending logon request message. | 2020-11-02 14:03:08.813 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:03:08.815 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:03:08.821 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:03:08.821 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:03:10.840 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:03:11.766 Rithmic Trading | Received logon response. | 2020-11-02 14:03:11.766 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:03:11.766 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:03:11.767 Rithmic Trading | Logon error received from server | 2020-11-02 14:03:11.767 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:11.767 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:11.767 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:03:11.840 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:03:11.840 Rithmic Trading | Disconnected. | 2020-11-02 14:03:11.840 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:11.840 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:03:11.840 Rithmic Trading | Port for executable: 64168 | 2020-11-02 14:03:13.848 Listening socket (1380). Port 64168 | Closed. | 2020-11-02 14:03:13.848 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:13.850 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:13.919 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:15.914 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64168 | 2020-11-02 14:03:15.914 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:15.914 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:15.914 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:17.947 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:17.947 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:17.947 DTC Client socket (2) | Closed. | 2020-11-02 14:03:17.947 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:17.947 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:17.964 Rithmic Trading | Disconnected. | 2020-11-02 14:03:17.964 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:17.964 Rithmic Trading | Port for executable: 64170 | 2020-11-02 14:03:19.969 Listening socket (580). Port 64170 | Closed. | 2020-11-02 14:03:19.969 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:19.970 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:20.019 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:22.032 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64170 | 2020-11-02 14:03:22.032 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:22.032 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:22.033 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:24.051 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:24.051 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:24.052 DTC Client socket (2) | Closed. | 2020-11-02 14:03:24.052 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:24.052 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:24.081 Rithmic Trading | Disconnected. | 2020-11-02 14:03:24.081 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:24.081 Rithmic Trading | Port for executable: 64172 | 2020-11-02 14:03:26.086 Listening socket (1436). Port 64172 | Closed. | 2020-11-02 14:03:26.086 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:26.089 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:26.139 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:28.141 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64172 | 2020-11-02 14:03:28.141 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:28.141 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:28.141 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:30.194 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:30.194 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:30.194 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:30.194 DTC Client socket (2) | Closed. | 2020-11-02 14:03:30.194 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:30.211 Rithmic Trading | Disconnected. | 2020-11-02 14:03:30.211 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:30.211 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:03:31.905 DTC Client socket (1) | Closed. | 2020-11-02 14:03:31.906 Rithmic Trading | Port for executable: 64174 | 2020-11-02 14:03:32.217 Listening socket (924). Port 64174 | Closed. | 2020-11-02 14:03:32.217 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:32.218 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:32.254 Rithmic Trading | Bridge process is running. | 2020-11-02 14:03:34.254 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64174 | 2020-11-02 14:03:34.254 DTC Client socket (1) | Creating socket. | 2020-11-02 14:03:34.254 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:34.254 Rithmic Trading | Connected to server. | 2020-11-02 14:03:34.257 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:03:34.257 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:03:34.257 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:03:34.260 Rithmic Trading | Sending logon request message. | 2020-11-02 14:03:34.260 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:03:34.263 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:03:34.266 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:03:34.266 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:03:36.094 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:03:36.977 Rithmic Trading | Received logon response. | 2020-11-02 14:03:36.977 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:03:36.977 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:03:36.977 Rithmic Trading | Logon error received from server | 2020-11-02 14:03:36.977 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:36.977 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:36.977 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:03:37.003 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:03:37.003 Rithmic Trading | Disconnected. | 2020-11-02 14:03:37.003 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:37.003 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:03:37.003 Rithmic Trading | Port for executable: 64189 | 2020-11-02 14:03:39.017 Listening socket (1436). Port 64189 | Closed. | 2020-11-02 14:03:39.017 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:39.020 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:39.048 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:41.051 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64189 | 2020-11-02 14:03:41.051 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:41.051 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:41.051 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:43.101 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:43.101 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:43.101 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:43.101 DTC Client socket (2) | Closed. | 2020-11-02 14:03:43.101 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:43.119 Rithmic Trading | Disconnected. | 2020-11-02 14:03:43.119 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:43.119 Rithmic Trading | Port for executable: 64191 | 2020-11-02 14:03:45.126 Listening socket (976). Port 64191 | Closed. | 2020-11-02 14:03:45.126 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:45.127 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:45.158 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:47.182 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64191 | 2020-11-02 14:03:47.182 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:47.182 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:47.183 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:49.216 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:49.216 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:49.216 DTC Client socket (2) | Closed. | 2020-11-02 14:03:49.216 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:49.216 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:49.232 Rithmic Trading | Disconnected. | 2020-11-02 14:03:49.232 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:49.232 Rithmic Trading | Port for executable: 64193 | 2020-11-02 14:03:51.230 Listening socket (1436). Port 64193 | Closed. | 2020-11-02 14:03:51.230 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:51.233 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:51.281 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:03:53.295 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64193 | 2020-11-02 14:03:53.295 DTC Client socket (2) | Creating socket. | 2020-11-02 14:03:53.296 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:53.296 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:03:55.319 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:03:55.320 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:03:55.320 DTC Client socket (2) | Closed. | 2020-11-02 14:03:55.320 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:55.320 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:03:55.340 Rithmic Trading | Disconnected. | 2020-11-02 14:03:55.340 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:03:55.340 Rithmic Trading | Port for executable: 64196 | 2020-11-02 14:03:57.339 Listening socket (1444). Port 64196 | Closed. | 2020-11-02 14:03:57.339 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:03:57.346 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-02 14:03:57.371 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:03:57.371 DTC Client socket (1) | Closed. | 2020-11-02 14:03:57.372 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:03:57.391 Rithmic Trading | Bridge process is running. | 2020-11-02 14:03:59.391 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64196 | 2020-11-02 14:03:59.391 DTC Client socket (1) | Creating socket. | 2020-11-02 14:03:59.391 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:03:59.392 Rithmic Trading | Connected to server. | 2020-11-02 14:03:59.394 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:03:59.394 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:03:59.394 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:03:59.398 Rithmic Trading | Sending logon request message. | 2020-11-02 14:03:59.398 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:03:59.400 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:03:59.407 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:03:59.407 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:04:01.230 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:04:02.134 Rithmic Trading | Received logon response. | 2020-11-02 14:04:02.134 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:04:02.134 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:04:02.134 Rithmic Trading | Logon error received from server | 2020-11-02 14:04:02.134 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:02.134 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:02.134 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:04:02.150 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:04:02.150 Rithmic Trading | Disconnected. | 2020-11-02 14:04:02.150 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:04:02.150 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:02.150 Rithmic Trading | Port for executable: 64210 | 2020-11-02 14:04:04.156 Listening socket (980). Port 64210 | Closed. | 2020-11-02 14:04:04.156 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:04.157 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:04.201 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:06.202 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64210 | 2020-11-02 14:04:06.202 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:06.202 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:06.202 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:08.242 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:08.243 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:08.243 DTC Client socket (2) | Closed. | 2020-11-02 14:04:08.243 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:08.243 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:08.260 Rithmic Trading | Disconnected. | 2020-11-02 14:04:08.261 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:08.261 Rithmic Trading | Port for executable: 64212 | 2020-11-02 14:04:10.258 Listening socket (1436). Port 64212 | Closed. | 2020-11-02 14:04:10.258 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:10.259 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:10.290 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:12.292 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64212 | 2020-11-02 14:04:12.293 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:12.293 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:12.293 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:14.318 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:14.318 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:14.318 DTC Client socket (2) | Closed. | 2020-11-02 14:04:14.318 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:14.319 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:14.336 Rithmic Trading | Disconnected. | 2020-11-02 14:04:14.337 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:14.337 Rithmic Trading | Port for executable: 64214 | 2020-11-02 14:04:16.334 Listening socket (1436). Port 64214 | Closed. | 2020-11-02 14:04:16.334 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:16.335 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:16.379 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:18.386 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64214 | 2020-11-02 14:04:18.386 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:18.386 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:18.386 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:20.417 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:20.417 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:20.417 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:20.417 DTC Client socket (2) | Closed. | 2020-11-02 14:04:20.417 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:20.435 Rithmic Trading | Disconnected. | 2020-11-02 14:04:20.435 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:20.435 Rithmic Trading | Port for executable: 64216 | 2020-11-02 14:04:22.439 Listening socket (1444). Port 64216 | Closed. | 2020-11-02 14:04:22.439 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:22.440 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:22.472 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:04:22.477 DTC Client socket (1) | Closed. | 2020-11-02 14:04:22.477 Rithmic Trading | Bridge process is running. | 2020-11-02 14:04:24.479 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64216 | 2020-11-02 14:04:24.479 DTC Client socket (1) | Creating socket. | 2020-11-02 14:04:24.479 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:24.479 Rithmic Trading | Connected to server. | 2020-11-02 14:04:24.482 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:04:24.482 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:04:24.482 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:04:24.486 Rithmic Trading | Sending logon request message. | 2020-11-02 14:04:24.486 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:04:24.488 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:04:24.491 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:04:24.491 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:04:26.437 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:04:27.318 Rithmic Trading | Received logon response. | 2020-11-02 14:04:27.318 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:04:27.318 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:04:27.318 Rithmic Trading | Logon error received from server | 2020-11-02 14:04:27.318 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:27.318 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:27.318 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:04:27.345 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:04:27.345 Rithmic Trading | Disconnected. | 2020-11-02 14:04:27.346 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:04:27.346 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:27.346 Rithmic Trading | Port for executable: 64230 | 2020-11-02 14:04:29.350 Listening socket (1476). Port 64230 | Closed. | 2020-11-02 14:04:29.350 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:29.353 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:29.392 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:31.414 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64230 | 2020-11-02 14:04:31.414 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:31.414 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:31.414 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:33.441 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:33.441 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:33.441 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:33.441 DTC Client socket (2) | Closed. | 2020-11-02 14:04:33.441 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:33.459 Rithmic Trading | Disconnected. | 2020-11-02 14:04:33.459 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:33.459 Rithmic Trading | Port for executable: 64233 | 2020-11-02 14:04:35.470 Listening socket (1444). Port 64233 | Closed. | 2020-11-02 14:04:35.470 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:35.475 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:35.522 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:37.528 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64233 | 2020-11-02 14:04:37.528 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:37.528 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:37.529 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:39.561 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:39.566 DTC Client socket (2) | Closed. | 2020-11-02 14:04:39.566 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:39.567 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:39.567 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:39.593 Rithmic Trading | Disconnected. | 2020-11-02 14:04:39.593 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:39.593 Rithmic Trading | Port for executable: 64235 | 2020-11-02 14:04:41.611 Listening socket (1444). Port 64235 | Closed. | 2020-11-02 14:04:41.611 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:41.613 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:41.655 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:43.648 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64235 | 2020-11-02 14:04:43.648 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:43.648 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:43.648 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:45.682 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:45.682 DTC Client socket (2) | Closed. | 2020-11-02 14:04:45.682 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:45.682 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:45.682 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:45.700 Rithmic Trading | Disconnected. | 2020-11-02 14:04:45.700 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:45.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:04:47.571 DTC Client socket (1) | Closed. | 2020-11-02 14:04:47.571 Rithmic Trading | Port for executable: 64237 | 2020-11-02 14:04:47.700 Listening socket (980). Port 64237 | Closed. | 2020-11-02 14:04:47.700 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:47.701 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:47.745 Rithmic Trading | Bridge process is running. | 2020-11-02 14:04:49.739 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64237 | 2020-11-02 14:04:49.739 DTC Client socket (1) | Creating socket. | 2020-11-02 14:04:49.739 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:49.739 Rithmic Trading | Connected to server. | 2020-11-02 14:04:49.741 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:04:49.741 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:04:49.741 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:04:49.743 Rithmic Trading | Sending logon request message. | 2020-11-02 14:04:49.743 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:04:49.744 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:04:49.748 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:04:49.748 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:04:51.563 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:04:52.454 Rithmic Trading | Received logon response. | 2020-11-02 14:04:52.455 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:04:52.455 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:04:52.455 Rithmic Trading | Logon error received from server | 2020-11-02 14:04:52.455 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:52.455 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:52.455 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:04:52.475 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:04:52.475 Rithmic Trading | Disconnected. | 2020-11-02 14:04:52.475 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:04:52.475 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:52.475 Rithmic Trading | Port for executable: 64251 | 2020-11-02 14:04:54.477 Listening socket (980). Port 64251 | Closed. | 2020-11-02 14:04:54.477 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:04:54.478 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:04:54.509 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:04:56.510 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64251 | 2020-11-02 14:04:56.510 DTC Client socket (2) | Creating socket. | 2020-11-02 14:04:56.510 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:04:56.511 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:04:58.520 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:04:58.520 DTC Client socket (2) | Closed. | 2020-11-02 14:04:58.520 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:04:58.521 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:58.521 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:04:58.533 Rithmic Trading | Disconnected. | 2020-11-02 14:04:58.533 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:04:58.533 Rithmic Trading | Port for executable: 64253 | 2020-11-02 14:05:00.540 Listening socket (1484). Port 64253 | Closed. | 2020-11-02 14:05:00.540 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:05:00.544 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:05:00.580 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:05:02.586 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64253 | 2020-11-02 14:05:02.586 DTC Client socket (2) | Creating socket. | 2020-11-02 14:05:02.586 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:05:02.587 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:05:04.613 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:05:04.614 DTC Client socket (2) | Closed. | 2020-11-02 14:05:04.614 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:05:04.614 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:05:04.614 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:05:04.638 Rithmic Trading | Disconnected. | 2020-11-02 14:05:04.638 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:05:04.638 Rithmic Trading | Port for executable: 64255 | 2020-11-02 14:05:06.643 Listening socket (1456). Port 64255 | Closed. | 2020-11-02 14:05:06.644 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:05:06.644 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:05:06.674 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:05:08.677 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64255 | 2020-11-02 14:05:08.677 DTC Client socket (2) | Creating socket. | 2020-11-02 14:05:08.677 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:05:08.677 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:05:10.736 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:05:10.736 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:05:10.736 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:05:10.736 DTC Client socket (2) | Closed. | 2020-11-02 14:05:10.736 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:05:10.751 Rithmic Trading | Disconnected. | 2020-11-02 14:05:10.751 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:05:10.752 Rithmic Trading | Port for executable: 64257 | 2020-11-02 14:05:12.765 Listening socket (980). Port 64257 | Closed. | 2020-11-02 14:05:12.766 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:05:12.768 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:05:12.814 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-02 14:05:12.879 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:05:12.879 DTC Client socket (1) | Closed. | 2020-11-02 14:05:12.879 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:05:14.825 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64257 | 2020-11-02 14:05:14.825 DTC Client socket (1) | Creating socket. | 2020-11-02 14:05:14.825 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:05:14.825 File >> Disconnect selected. | 2020-11-02 14:05:16.375 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:05:16.375 Rithmic Trading | Disconnected. | 2020-11-02 14:05:16.375 DTC Client socket (1) | Closed. | 2020-11-02 14:05:16.375 Rithmic Trading | Port for executable: 64278 | 2020-11-02 14:08:50.565 Listening socket (1480). Port 64278 | Closed. | 2020-11-02 14:08:50.565 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:08:50.566 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:08:50.591 Rithmic Trading | Bridge process is running. | 2020-11-02 14:08:52.591 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64278 | 2020-11-02 14:08:52.591 DTC Client socket (1) | Creating socket. | 2020-11-02 14:08:52.591 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:08:52.592 Rithmic Trading | Connected to server. | 2020-11-02 14:08:52.601 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:08:52.601 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:08:52.601 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:08:52.603 Rithmic Trading | Sending logon request message. | 2020-11-02 14:08:52.603 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:08:52.605 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:08:52.611 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:08:52.611 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:08:54.625 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:08:55.503 Rithmic Trading | Received logon response. | 2020-11-02 14:08:55.504 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:08:55.504 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:08:55.504 Rithmic Trading | Logon error received from server | 2020-11-02 14:08:55.504 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:08:55.504 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:08:55.504 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:08:55.564 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:08:55.564 Rithmic Trading | Disconnected. | 2020-11-02 14:08:55.564 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:08:55.564 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:08:55.564 Rithmic Trading | Port for executable: 64292 | 2020-11-02 14:08:57.566 Listening socket (1488). Port 64292 | Closed. | 2020-11-02 14:08:57.566 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:08:57.567 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:08:57.616 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:08:59.616 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64292 | 2020-11-02 14:08:59.616 DTC Client socket (2) | Creating socket. | 2020-11-02 14:08:59.616 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:08:59.617 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:09:01.649 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:09:01.649 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:09:01.649 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:01.649 DTC Client socket (2) | Closed. | 2020-11-02 14:09:01.650 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:09:01.660 Rithmic Trading | Disconnected. | 2020-11-02 14:09:01.660 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:01.660 Rithmic Trading | Port for executable: 64295 | 2020-11-02 14:09:03.665 Listening socket (980). Port 64295 | Closed. | 2020-11-02 14:09:03.665 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:03.666 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:03.692 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:09:05.701 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64295 | 2020-11-02 14:09:05.701 DTC Client socket (2) | Creating socket. | 2020-11-02 14:09:05.702 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:05.702 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:09:07.732 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:09:07.732 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:09:07.732 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:07.732 DTC Client socket (2) | Closed. | 2020-11-02 14:09:07.732 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:09:07.750 Rithmic Trading | Disconnected. | 2020-11-02 14:09:07.750 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:07.750 Rithmic Trading | Port for executable: 64297 | 2020-11-02 14:09:09.753 Listening socket (1496). Port 64297 | Closed. | 2020-11-02 14:09:09.753 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:09.754 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:09.785 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:09:11.797 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64297 | 2020-11-02 14:09:11.797 DTC Client socket (2) | Creating socket. | 2020-11-02 14:09:11.797 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:11.797 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:09:13.819 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:09:13.819 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:09:13.819 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:13.819 DTC Client socket (2) | Closed. | 2020-11-02 14:09:13.819 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:09:13.839 Rithmic Trading | Disconnected. | 2020-11-02 14:09:13.839 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:13.839 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:09:15.718 DTC Client socket (1) | Closed. | 2020-11-02 14:09:15.718 Rithmic Trading | Port for executable: 64299 | 2020-11-02 14:09:15.831 Listening socket (1500). Port 64299 | Closed. | 2020-11-02 14:09:15.831 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:15.833 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:15.884 Rithmic Trading | Bridge process is running. | 2020-11-02 14:09:17.879 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64299 | 2020-11-02 14:09:17.879 DTC Client socket (1) | Creating socket. | 2020-11-02 14:09:17.879 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:17.879 Rithmic Trading | Connected to server. | 2020-11-02 14:09:17.882 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:09:17.882 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:09:17.882 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:09:17.886 Rithmic Trading | Sending logon request message. | 2020-11-02 14:09:17.886 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:09:17.889 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:09:17.892 Rithmic Trading | Message from server: Connecting to Rithmic Test server. | 2020-11-02 14:09:17.892 File >> Disconnect selected. | 2020-11-02 14:09:18.054 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:09:18.054 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:09:18.055 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:09:18.055 Rithmic Trading | Disconnected. | 2020-11-02 14:09:18.055 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:09:20.981 DTC Client socket (1) | Closed. | 2020-11-02 14:09:20.981 Rithmic Trading | Port for executable: 64307 | 2020-11-02 14:09:22.097 Listening socket (1456). Port 64307 | Closed. | 2020-11-02 14:09:22.097 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:22.099 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:22.124 Rithmic Trading | Bridge process is running. | 2020-11-02 14:09:24.118 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64307 | 2020-11-02 14:09:24.118 DTC Client socket (1) | Creating socket. | 2020-11-02 14:09:24.119 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:24.119 Rithmic Trading | Connected to server. | 2020-11-02 14:09:24.121 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:09:24.121 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:09:24.122 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:09:24.125 Rithmic Trading | Sending logon request message. | 2020-11-02 14:09:24.125 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:09:24.128 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:09:24.131 Rithmic Trading | Message from server: Connecting to Rithmic Test server. | 2020-11-02 14:09:24.131 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:09:25.759 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:09:26.590 Rithmic Trading | Received logon response. | 2020-11-02 14:09:26.590 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:09:26.590 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:09:26.590 Rithmic Trading | Logon error received from server | 2020-11-02 14:09:26.590 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:09:26.590 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:26.590 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:09:26.668 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:09:26.668 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:09:26.668 Rithmic Trading | Disconnected. | 2020-11-02 14:09:26.668 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:26.669 Rithmic Trading | Port for executable: 64321 | 2020-11-02 14:09:28.660 Listening socket (1396). Port 64321 | Closed. | 2020-11-02 14:09:28.660 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:28.662 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:28.696 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:09:30.695 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64321 | 2020-11-02 14:09:30.695 DTC Client socket (2) | Creating socket. | 2020-11-02 14:09:30.695 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:30.695 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:09:32.734 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:09:32.734 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:09:32.734 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:32.734 DTC Client socket (2) | Closed. | 2020-11-02 14:09:32.734 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:09:32.743 Rithmic Trading | Disconnected. | 2020-11-02 14:09:32.743 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:09:32.743 File >> Disconnect selected. | 2020-11-02 14:09:34.556 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:09:34.556 Rithmic Trading | Disconnected. | 2020-11-02 14:09:34.556 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:09:47.224 DTC Client socket (1) | Closed. | 2020-11-02 14:09:47.224 Rithmic Trading | Port for executable: 64324 | 2020-11-02 14:09:57.441 Listening socket (1452). Port 64324 | Closed. | 2020-11-02 14:09:57.441 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:09:57.442 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:09:57.468 Rithmic Trading | Bridge process is running. | 2020-11-02 14:09:59.485 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64324 | 2020-11-02 14:09:59.485 DTC Client socket (1) | Creating socket. | 2020-11-02 14:09:59.485 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:09:59.485 Rithmic Trading | Connected to server. | 2020-11-02 14:09:59.488 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:09:59.488 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:09:59.488 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:09:59.492 Rithmic Trading | Sending logon request message. | 2020-11-02 14:09:59.492 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:09:59.494 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:09:59.498 Rithmic Trading | Message from server: Connecting to Rithmic 01 Colo 75 server. | 2020-11-02 14:09:59.498 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2020-11-02 14:10:00.989 Rithmic Trading | Received logon response. | 2020-11-02 14:10:00.989 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:10:00.989 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:10:00.989 Rithmic Trading | Logon error received from server | 2020-11-02 14:10:00.989 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:00.989 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:00.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:10:00.991 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:01.027 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-11-02 14:10:01.027 DTC Client socket (1) | Closed. | 2020-11-02 14:10:01.027 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:10:01.030 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:01.030 Rithmic Trading | Disconnected. | 2020-11-02 14:10:01.030 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:01.030 Rithmic Trading | Port for executable: 64326 | 2020-11-02 14:10:03.033 Listening socket (1396). Port 64326 | Closed. | 2020-11-02 14:10:03.033 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:03.036 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:03.083 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:10:05.084 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64326 | 2020-11-02 14:10:05.084 DTC Client socket (1) | Creating socket. | 2020-11-02 14:10:05.084 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:10:05.084 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:10:07.111 * DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:07.111 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:07.111 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:07.111 DTC Client socket (1) | Closed. | 2020-11-02 14:10:07.111 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:07.141 Rithmic Trading | Disconnected. | 2020-11-02 14:10:07.141 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:07.141 Rithmic Trading | Port for executable: 64328 | 2020-11-02 14:10:09.174 Listening socket (1396). Port 64328 | Closed. | 2020-11-02 14:10:09.174 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:09.176 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:09.207 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:10:11.210 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64328 | 2020-11-02 14:10:11.211 DTC Client socket (1) | Creating socket. | 2020-11-02 14:10:11.211 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:10:11.211 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:10:13.251 * DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:13.251 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:13.251 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:13.251 DTC Client socket (1) | Closed. | 2020-11-02 14:10:13.251 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:13.271 Rithmic Trading | Disconnected. | 2020-11-02 14:10:13.271 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:13.271 Rithmic Trading | Port for executable: 64330 | 2020-11-02 14:10:15.284 Listening socket (1480). Port 64330 | Closed. | 2020-11-02 14:10:15.284 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:15.286 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:15.328 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:10:17.342 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64330 | 2020-11-02 14:10:17.342 DTC Client socket (1) | Creating socket. | 2020-11-02 14:10:17.342 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:10:17.343 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:10:19.373 * DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:19.373 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:19.373 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:19.373 DTC Client socket (1) | Closed. | 2020-11-02 14:10:19.373 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:19.390 Rithmic Trading | Disconnected. | 2020-11-02 14:10:19.390 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:19.390 Rithmic Trading | Port for executable: 64332 | 2020-11-02 14:10:21.395 Listening socket (1424). Port 64332 | Closed. | 2020-11-02 14:10:21.395 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:21.397 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:21.427 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:10:23.445 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64332 | 2020-11-02 14:10:23.445 DTC Client socket (1) | Creating socket. | 2020-11-02 14:10:23.445 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:10:23.446 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:10:25.476 * DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:25.476 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:25.476 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:25.476 DTC Client socket (1) | Closed. | 2020-11-02 14:10:25.476 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:25.496 Rithmic Trading | Disconnected. | 2020-11-02 14:10:25.496 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:25.496 Rithmic Trading | Port for executable: 64334 | 2020-11-02 14:10:27.492 Listening socket (1424). Port 64334 | Closed. | 2020-11-02 14:10:27.492 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:27.495 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:27.537 Rithmic Trading | Bridge process is running. | 2020-11-02 14:10:29.547 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64334 | 2020-11-02 14:10:29.547 DTC Client socket (1) | Creating socket. | 2020-11-02 14:10:29.547 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:10:29.548 Rithmic Trading | Connected to server. | 2020-11-02 14:10:29.550 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:10:29.550 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:10:29.550 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:10:29.554 Rithmic Trading | Sending logon request message. | 2020-11-02 14:10:29.554 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:10:29.558 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:10:29.561 Rithmic Trading | Message from server: Connecting to Rithmic 01 Colo 75 server. | 2020-11-02 14:10:29.561 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2020-11-02 14:10:30.657 Rithmic Trading | Received logon response. | 2020-11-02 14:10:30.658 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:10:30.658 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:10:30.658 Rithmic Trading | Logon error received from server | 2020-11-02 14:10:30.658 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:10:30.658 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:30.658 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:10:30.658 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:10:30.697 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-11-02 14:10:30.697 DTC Client socket (1) | Closed. | 2020-11-02 14:10:30.697 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:10:30.701 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:30.701 Rithmic Trading | Disconnected. | 2020-11-02 14:10:30.701 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:10:30.701 Rithmic Trading | Port for executable: 64337 | 2020-11-02 14:10:32.699 Listening socket (1480). Port 64337 | Closed. | 2020-11-02 14:10:32.699 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:10:32.701 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:10:32.757 File >> Disconnect selected. | 2020-11-02 14:10:34.129 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:10:34.129 Rithmic Trading | Disconnected. | 2020-11-02 14:10:34.129 Rithmic Trading | Port for executable: 64340 | 2020-11-02 14:11:16.656 Listening socket (1448). Port 64340 | Closed. | 2020-11-02 14:11:16.656 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:11:16.657 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:11:16.704 Rithmic Trading | Bridge process is running. | 2020-11-02 14:11:18.720 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64340 | 2020-11-02 14:11:18.720 DTC Client socket (1) | Creating socket. | 2020-11-02 14:11:18.720 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:11:18.720 Rithmic Trading | Connected to server. | 2020-11-02 14:11:18.723 Rithmic Trading | Starting socket receive thread. | 2020-11-02 14:11:18.723 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-11-02 14:11:18.723 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-11-02 14:11:18.726 Rithmic Trading | Sending logon request message. | 2020-11-02 14:11:18.726 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-11-02 14:11:18.729 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-11-02 14:11:18.732 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-11-02 14:11:18.732 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-11-02 14:11:23.516 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-11-02 14:11:24.436 Rithmic Trading | Received logon response. | 2020-11-02 14:11:24.436 Rithmic Trading | Server Name: DTC Bridge. | 2020-11-02 14:11:24.436 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-11-02 14:11:24.436 Rithmic Trading | Logon error received from server | 2020-11-02 14:11:24.436 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:11:24.436 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:11:24.436 Rithmic Trading | Waiting for socket receive thread to end | 2020-11-02 14:11:24.473 DTC Client socket (1) | CloseSocket call. | 2020-11-02 14:11:24.473 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-02 14:11:24.473 Rithmic Trading | Disconnected. | 2020-11-02 14:11:24.474 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:11:24.474 Rithmic Trading | Port for executable: 64355 | 2020-11-02 14:11:26.483 Listening socket (1464). Port 64355 | Closed. | 2020-11-02 14:11:26.483 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:11:26.484 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:11:26.534 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:11:28.541 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64355 | 2020-11-02 14:11:28.541 DTC Client socket (2) | Creating socket. | 2020-11-02 14:11:28.541 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:11:28.542 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-11-02 14:11:30.577 * DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:11:30.578 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-02 14:11:30.578 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:11:30.578 DTC Client socket (2) | Closed. | 2020-11-02 14:11:30.578 DTC Client socket (0) | CloseSocket call. | 2020-11-02 14:11:30.595 Rithmic Trading | Disconnected. | 2020-11-02 14:11:30.596 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-02 14:11:30.596 Rithmic Trading | Port for executable: 64357 | 2020-11-02 14:11:32.598 Listening socket (1480). Port 64357 | Closed. | 2020-11-02 14:11:32.598 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-11-02 14:11:32.599 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-11-02 14:11:32.630 Rithmic Trading | Bridge process is not running! | 2020-11-02 14:11:34.637 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64357 | 2020-11-02 14:11:34.637 DTC Client socket (2) | Creating socket. | 2020-11-02 14:11:34.637 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-11-02 14:11:34.638 File >> Disconnect selected. | 2020-11-02 14:11:36.496 DTC Client socket (2) | CloseSocket call. | 2020-11-02 14:11:36.496 Rithmic Trading | Disconnected. | 2020-11-02 14:11:36.496 DTC Client socket (2) | Closed. | 2020-11-02 14:11:36.496 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-11-02 14:11:46.822 DTC Client socket (1) | Closed. | 2020-11-02 14:11:46.822 |
| [2020-11-02 19:59:58] |
| John - SC Support - Posts: 48459 |
We do not recommend using Rithmic with Sierra Chart, as we have stopped technical support for Rithmic. Refer to the following thread for the files you need in order to connect to Rithmic: Rithmic Bridge Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-02 22:39:15] |
Have a look instead at using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
