Date/Time: Sun, 19 May 2024 14:54:41 +0000
Copy to Chart.bpm
View Count: 654
[2020-11-01 23:37:19] |
User589069 - Posts: 6 |
Hello, Is it possible to change the default program that "Copy to chart.bmp" opens with. Currently it opens with MS Paint. Is it possible to change to a different graphics program? like paint.net. Thanks |
[2020-11-02 00:16:59] |
Yes we will add a setting for this.
[2020-11-02 00:19:05] |
Actually looking at how this is done, you just need to associate BMP files with that program you mention, on your system. This will do it.
[2020-11-02 02:03:56] |
Hello, I do have bmp set to open with snipping tool but it still opens it with paint. Thank you! |
[2020-11-02 02:26:15] |
Nowhere in Sierra Chart does it specify to use MS Paint. We simply use a function to open the file and the OS chooses the program to use. But we do specify that an Edit operation needs to be performed. That could be what is causing Paint to be used. However, you can change that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-02 02:26:54
[2020-11-02 02:37:40] |
Thank you. Here is a link on how to change it on Windows 10. https://www.winhelponline.com/blog/change-default-image-editor-edit-command-right-click-image/ |
