Date/Time: Sun, 19 May 2024 16:26:00 +0000
Sierra Order Routing + AMP execution time
View Count: 508
[2020-10-31 13:34:57] |
User978290 - Posts: 25 |
Hi, Just wondering if the execution time is normal here. -using Spreadsheet Study auto trade -on lan -using default servers -im in Hong Kong at the moment -symbol ES Under the activity log, From the time I see the Autotrade trigger to the sierra routing took 0.617 secs and from routing to filled is 0.004 Would that be considered a normal range speed? From trigger to routing. Will it make a difference if the trigger was all in acsil? Or if choosen other servers? Thanks! |
[2020-10-31 13:55:24] |
One thing we know is that it is hard for users to get accurate measurements as to execution times by looking at the Trade Activity Log for various reasons. So what you see is not necessarily accurate. Although certainly when an order is received to one of our order routing servers in Aurora, Illinois, USA, the routing time will be below a millisecond. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 13:55:40
