Date/Time: Fri, 03 May 2024 09:10:25 +0000
Unable to resize TPO chart
View Count: 1111
[2014-02-12 19:27:03] |
OneMoreTick - Posts: 79 |
I have several charts in a chartbook and am unable to resize the TPO chart. All other charts can be resized normally. When I "restore" my TPO chart, it gets maximized. I'm unable to drag the corners/sides to make it bigger or smaller. It can only be maximized or minimized.
[2014-02-12 19:51:58] |
When it comes to adjusting the size of a chart window, it does not matter what the content of the chart window is. It is not going to affect that. When the chart is Maximized go to Window >> Restore to restore it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 20:17:12] |
When I go to Window >> Restore, the window minimizes and is not available to resize. It's only visible as a tab. It's something with this particular chart. Is there some other setting somewhere relating to resizing? I created a new chartbook and the issue is not occurring. When I copy the "problem" chart to a new chartbook, the problem still exists. I'll create a new chartbook and try to replicate the problem charts to new charts. |
[2014-02-12 20:29:40] |
This is very unusual behavior and we do not know the reason for this. And would indicate a problem with the operating system. We recommend restarting Sierra Chart and if there still is a problem restart your computer. Or you can just create new charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-12 20:29:57
