Date/Time: Sun, 05 May 2024 21:15:26 +0000
Rectangle Drawing Tool
View Count: 948
[2014-02-12 18:37:57] |
Discount - Posts: 73 |
Is there any setting where you can draw a rectangle from your drawing tools, and select some setting where this rectangle will go to the right like a Ray drawing tool will? Something like a Rectangle Ray?
[2014-02-12 20:09:43] |
Yes. This is called Tools >> Extending Rectangle.
