Date/Time: Sat, 21 Nov 2026 10:29:42 +0000
How to make attached orders update from actual fills
View Count: 860
| [2020-10-29 16:57:07] |
| User433715 - Posts: 4 |
I had a buy stop order at 11307.50 and had attached order target at 11334.25. Buy stop got filled 2 ticks higher due to slip, but the TP did not update to 11334.75 from the fills. I thought it's supposed to do this (at least in CQG platform it does) I checked the average position setting and it was FIFO. Should it be set to flat to flat? or LIFO? Please help me determine how i can have the attached order TP and STOP to update after it's filled. See image Date Time Of Last Edit: 2020-10-29 17:03:15
| [2020-10-29 17:33:36] |
| John - SC Support - Posts: 48610 |
Refer to the following information: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-29 20:51:26] |
You should also really look at using the Sierra Chart Order Routing Service: Sierra Chart Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
