Date/Time: Sun, 19 May 2024 15:52:29 +0000
Left Side Value Scale on chart
View Count: 957
[2020-10-29 13:03:35] |
User882670 - Posts: 15 |
After recent update my left values scale isn't being displayed. On one chart it is displaying only part of it - like the chart window wasnt fully visible And on the other chart it isnt visible at all |
2020-10-29_09-02-15.jpg / V - Attached On 2020-10-29 13:02:52 UTC - Size: 35.88 KB - 220 views |
[2020-10-31 14:22:47] |
Check this setting for each of the studies and main price graph using the left side scale: Chart Scale and Scale Adjusting: Include in Scale Width Calculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 14:23:07
[2020-11-02 11:56:04] |
Little bit misleading mentioning each of the studies, because this setting is only in the chart settings->scale. But anyway - that fixed the issue, thanks |
