Date/Time: Sat, 04 May 2024 06:42:08 +0000
Buy Second License
View Count: 1769
[2013-04-18 06:30:52] |
KhaosTrader - Posts: 128 |
Dear Sirs, I am thinking of purchasing a second license for myself because I would like to run a second copy on a second machine so that I can do custom study development on one machine as I trade on the other -- and also I have 3 different broker accounts so sometimes its easier to have multiple machines do to cpu overhead.. I have the following questions: 1) do i need to create another username? or can I just buy the second license under this username? 2) is there a discount if I purchase a second license? I am aware I can run the software on multiple machines, i just cant have it run concurrently using 1 license. However I wish to run this on 2 machines concurrently, so a second license would be required. I currently have a level 5 service package. Thanks |
[2013-04-18 08:00:00] |
1, 2. You can already use your existing Account Name with Sierra Chart on 2 different computers at the same time.
[2013-04-18 08:35:45] |
Wow, thats great. Where can I read about the limitations and concepts of licensing? I assume that I am ok with running it on several computers, but no more than 2 at a given moment, i assume? |
[2013-04-18 08:40:57] |
This page: http://www.sierrachart.com/index.php?l=doc/PurchaseInformation.php You can install Sierra Chart on 1000 computers if you want. However, you can only use 2 of them at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-19 00:07:07] |
Excellent policy to allow 2 computers to use it at the same time, I appreciate it this very much, thx.
[2013-06-17 18:35:36] |
shanley - Posts: 11 |
Great to know. However, I tried it and no joy. Is there anything I need to do differently?
[2013-06-17 18:45:52] |
Your account is not a direct account which you pay directly to Sierra Chart. You will need a direct account to be able to use Sierra Chart on more than 1 system at a time. Please follow these instructions: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
