Date/Time: Mon, 20 May 2024 04:42:16 +0000
New column every second even if no data?
View Count: 415
[2020-10-27 23:21:10] |
User128888 - Posts: 30 |
I have a chart set at 1 second time frame. In Advanced Settings, I have "Include Columns With No Data" checked. Currently, if there is no data, the new column will not print. It waits until there's data before it prints again and printing the columns with no data. I check the spreadsheet and it functions in the same way. For the chart, is there a way to force it to show the column even if no data came in? I was thinking of using a workaround like using a different study to print something every second but didn't see anything that seemed to do this. Thanks. |
[2020-10-30 19:01:13] |
No this is not technically possible to do what you want. But have a look at this ACSIL functionality: ACSIL Interface Members - Variables and Arrays: sc.IsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-30 19:01:47
