Date/Time: Mon, 06 May 2024 22:36:58 +0000
conditional order question
View Count: 1014
[2014-02-12 16:05:58] |
User90752 - Posts: 1 |
Hi, I have 2 questions. First question. Can you set a conditional order that if price trades at a certain price you can buy or sell on a limit? An example would be if es trades down to 1800.00 you want to sell on a limit at 1805.00. Second question. Is it possible to place an OCO order on the condition that if price trades at a certain price then the OCO order will be placed? Thanks, |
[2014-02-12 18:51:13] |
1. Yes you can do this. There is a study which supports this: https://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#TriggeredLimitOrderEntryStudy 2. Is it possible to place an OCO order on the condition that if price trades at a certain price then the OCO order will be placed?
There is not built-in support for this, but you could create your own custom trading study to do this. Help with this is outside the scope of our support. Refer to this page:http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
