Date/Time: Mon, 20 May 2024 02:27:26 +0000
Spreadsheet
View Count: 422
[2020-10-27 12:31:37] |
User170575 - Posts: 221 |
Hi--using the spreadsheet study for trading I was retrieving data going back ten years--alot of equations--now when I reduced the the number of days on the chart to 3 the equations I had on the sheet are still there past the 3 days--all the way back to the ten year range. This makes SC a little sticky. Is there a simple way to clear the spreadsheet equations to just the range of the chart? Many thx, Cy |
[2020-10-27 13:47:39] |
cancel that---got it
[2020-10-30 18:58:46] |
Refer to: Using the Spreadsheet Study: Clearing Old Study and Other Data from Spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
