Date/Time: Sat, 18 May 2024 06:48:27 +0000
Regarding Different DMI Values
View Count: 23855
[2020-10-26 18:11:08] |
User845829 - Posts: 3 |
This issue is regarding the DMI study on the 377 tick chart. Different PCs tend to show different values of the DI+, DI- and ADX. Additionally, neither of the instances of Sierra match up with ThinkOrSwim DMI values. However, the time frame charts (e.g. 1m, 5m, 15m, etc) seem to match up (for the most part, still some discrepancy). I'm not sure why this is the case for the tick charts or why it would possibly calculate differently? Which are the correct values?
[2020-10-26 20:59:42] |
Regarding charts based upon Number of Trades per Bar, refer to: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent For the formula used in the calculations, refer to: Directional Movement Index Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
