Date/Time: Thu, 02 May 2024 18:57:08 +0000
FOREX DATA
View Count: 1095
[2014-02-12 13:42:19] |
User82615 - Posts: 106 |
HELLO HOW CAN I GET FOREX DATA FOR EURO /DOLLAR ? THANK YOU |
[2014-02-12 15:31:37] |
Sierra Chart - Max - Posts: 5598 |
To get Forex Data, you can use the Sierra Chart Real Time and Historical Forex and CFD Data Service service: http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support |
[2014-02-12 19:43:19] |
THANK YOU VERY MUCH FOR YOUR HELP. COULD YOU TELL ALSO ME WHERE COULD I SEE THE PRICES FOR HAVING THIS DATA? THANK YOU VERY MUCH |
[2014-02-12 19:45:42] |
You will need Sierra Chart package 3 or 5: http://www.sierrachart.com/index.php?l=doc/Packages.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-13 11:54:56] |
I HAVE PACKAGE 5. CAN I GET ALREADY FOREX DATA? THANK YOU |
[2014-02-13 18:34:31] |
Yes. Refer to this page: http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
