Date/Time: Sat, 18 May 2024 00:29:13 +0000
Account activation
View Count: 385
[2020-10-26 15:14:34] |
dizzydes - Posts: 1 |
Once activated I'd like access to the data outlined here https://www.sierrachart.com/index.php?page=doc/helpdetails59.php, if you could also let me know any additional steps required for that
[2020-10-26 16:27:45] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". ---------------------------- The data that is referenced on that page is available at no extra cost and does not require any special setup. Therefore, you should have access to it without having to do anything. Just select File >> Find Symbol to select a symbol to get started charting with. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
