Date/Time: Sat, 18 May 2024 05:59:31 +0000
Sierra Chart/Windows 10 4k issue
View Count: 526
[2020-10-25 21:21:55] |
User259545 - Posts: 24 |
I have a 4k display monitor that I have been using with Sierra Chart and Windows 10. It has work great up until a number of months ago when I went to upgrade my Windows build. With any Windows build after 17134 my Sierra Chart comes up in HD instead of UHD. I log into Sierra Chart through my TransAct account. All other programs display in 4K UHD except my Sierra Chart. I was hoping that a subsequent release of Windows would fix the situation, but no such luck. I am using the current version of Sierra Chart (2182). Any light you could shed on this issue would be greatly appreciated. Best Regards, Brett Walker |
[2020-10-25 22:22:02] |
What exactly does this mean?: my Sierra Chart comes up in HD instead of UHD.
