Date/Time: Sat, 18 May 2024 07:58:46 +0000
Storage
View Count: 442
[2020-10-25 18:53:00] |
User161549 - Posts: 81 |
Sierra chart has used up the remaining storage in my PC it seems this problem occurred a few days after I started using a sub instance of sierra chart for quicker updates on my smaller time frame charts is there any correlation there that would link to additional storage being used ? Also it took me a couple times to get the sub instance to work correctly i was instructed to go to File-> New instance and after doing that a couple times i noticed in the windows explorer file I had two seperate folders one saying "Sierra chart instance 2" and "Sierra chart instance 3" my question is do I delete those additional folders ? |
[2020-10-25 20:16:03] |
Each sub instance does maintain its own copy of the data. "Sierra chart instance 3" Delete this one.
[2020-10-25 20:31:26] |
Okay i deleted that one but still no real change in my storage usage, Would you say the creation of the separate instance is the issue im having here in regards to using a bunch of extra storage or it shouldnt have that much of an affect ? Do i just delete the other sub instance and stay away from that route or is there any other things i can try to free up space ? My data currently will not work until i can get more space freed up |
